fiberglass repairs
Old 04-01-02, 07:26 AM
A
fiberglass repairs
what prep is required to lay in a new floor, mine's getting kinda spongy and much of the gelcoat (that cheap splatter paint looking stuff) is worn away. I think they used cropped glass sprayed in over a mold as opposed to layed in glass. After I lay on some new glass, what are the best choices for durable deck coatings?
Also, my brother in law ran us into a piling the other day and did a fair amount of damage on the side rail, no damage to the side of the boat just the top rail is completely cracked through, I was thinking of grinding away the edges on the top, bottom, and sides at the cracks and glassing in over the existing piece as a patch?
Old 04-01-02, 07:58 PM
BoatMech's Avatar
Normally its the underlying wood that is rotted from
rainwater. and subsequently the fiberglass delaminates
from it. the best fix is to cut opurt the floor boards and
lay up a new sheet of plywood, coated o both sides with
resin and glassed into place securely.
but you can in a pinch lay a fresh sheet over the existing floor.
what exactly are we talking about, the entire deck or
just the area around the stern? Inboard/ outboard
stern drive? Bayliner, deck boat?
