patching aluminum engine cover
Old 04-21-02, 02:12 PM
stilllearning23
1980 Evinrude 4 HP aluminum engine cover -- has several 3 inch by 2 inch chunks of aluminum surface area missing . I am trying to fashion repair patches . Any suggestions as to a suitable material that will bond to the aluminum and also withstand the rigors of the engine vibrations ? Bondo ? Epoxy ? Fiberglass?
Old 04-22-02, 01:51 AM
B
bazman
Cool Patching aluminum
Cut a thin piece of tin and put it on the inside of the hole. Then use a putty type metal repair. It hold it's shape when drying. Press the putty onto the tin and over the outside of the hole. When it drys you can sand it down and paint it. I use metal putty repair on plastic an aluminum and it works great. You can get it at any automotive supply store or hardware store.
Old 04-22-02, 05:57 AM
stilllearning23
Thank you Bazman . I'll check the auto store for metal putty repair stuff. Any brand recommendations ?
Old 04-22-02, 05:36 PM
B
bazman
Patching aluminum
I'm not sure if JB weld makes this product but if you ask the counter person they should be able to put on the right trac.
