Mercury Outboard 25H leaking propeller shaft oil
sharron_72064's Avatar
06-17-02, 06:44 PM   #1
sharron_72064
I have a 97 Mercury Outboard 25H that is leaking oil around the propeller shaft. Can I repair it myself, if so how?? Thanks, Stan
06-20-02, 02:48 PM   #2
sharron_72064
Mr. Boat Mech., please help
I have a 97 Mercury 25H that is leaking oil around the propeller shaft.Can I repair this myself, and if so, how? Thanks
BoatMech's Avatar
06-22-02, 06:16 AM   #3
You say the propshaft seals are leaking?
You got some fishing line in them didn't you?
By removing the bearing carrier you will be able to
replace the seals. Not a big job, if you have a
puller and some patience. Get a service manual
by Seloc or Haynes, and read up on the lower unit
section. You may want to replace the water pump
impeller while you are down there.
scott
Moderator Note:
Both topics, on this same subject, have been merged together.
Regards, Good Luck & Safe Boating
Forum Host & Moderator
Tom_Bart
TCB4U2B2B Company Enterprises.
