Go-Kart wont stay started
Old 02-14-04, 03:25 PM
blake
I have a Manco go-kart with a 6hp Tecumseh Engine. It will start and idle but when I give it gas it boggs down and dies. I think that it is a problem with the air/gas ratio but I can't find where to adjust it at on the engine.
Any help is appreciated.
Old 02-22-04, 03:27 PM
keith_byers
re
i have the exact same go-cart ... how funny ...
the adjustment screws are located on the back of the carb
there will be two screww one on top and one on the bottom ..
the one on top is your idle adjustment scew ..the bottom one is your speed screw
adjust those .see if it helps
start with the idle , just to keep it running while you play with the other
Old 02-22-04, 08:58 PM
blake
Thanks! it runs perfectly now!
