what engine should i use ?(building go-kart)
Hi im in the middle of building a go kart and i have a chose of engines .
snowmoble
1. is a 340cc and the other is a 440cc which one should i choose
thnx for the help .
does any body no how to make axles and is a 5hp better then theses to and how fast will each engine go thnx again
snowmoble
thnx for the help .
I'd use the 440cc, but if you're more into control or off-roading type usage, then I'd suggest the 340cc. If you want high performance/speed, go with the 440.
You could probably find some axles at a junkyard, that's where I find a lot of my things.
