blaster throttle problem
Old 07-10-04, 11:07 PM
jncgragg
Question blaster throttle problem
2000 yamaha blaster cranks & runs but when you push on throttle it dies spark plug is wet with gas "i can idle it up as high as i want and the engine gets faster i can also idle it up high and ride it shfting all gears but go up hill and bogs down"i took carb apart and cleaned it it started doing this when i was riding it if anyone can help i would be thankful
Old 08-21-04, 04:33 PM
fireace
blaster problems
check the float level in the carb your machine is flooding it`self out sounds like the float needs reset and maybe you may want to see if you need a jet change
