Honda big red 200
Old 10-17-04, 05:25 PM
Jordan Negaard
Honda big red 200
I have a honda big red 200. It only starts when you change the spark plug. But after 5 or so times starting it it doesn't start anymore. and when you take the spark plug off it is really wet with gas. so then you put a different spark plug in and it works again for a while. do you think it is an electrical problem? Help me Please!!!
Old 10-22-04, 03:36 AM
fire-medic8104
I would say you have a carb problem that is causing it to run too rich, which injects too much fuel into the combustion chamber.
Old 10-24-04, 06:52 PM
onourown's Avatar
I think you have a carb problem as well, most likely a high fuel level in the bowl. Look for a dirty/sticky/worn float or float valve.
Old 10-30-04, 02:14 PM
gas
and or check to be sure you are getting enough air, clean filter and check air fuel mix on the carb.
