Question about ignition coil
Old 02-26-05, 12:54 PM
jad1682
I have a 1973 mt250 honda dirtbike and I think the coil may be gone. It puts out a little bit of a spark but not enough to keep the bike running. Do you think that running a cylindrical ignition coil off of an older model car could work to make the spark and fire the bike. Could the problem not be cause by the coil but the magneto itself???
Old 02-28-05, 06:50 AM
diagnosticmonke
1973 hmmmm, sounds like points to me . check under the flywheel to see if-n-u-got points under there.usually looking thru the openings in the outside of the flywheel with a lite will tell you the answer.
