go cart problems
Old 03-03-05, 08:35 AM
skater_punk8
go cart clutch problems
I am planing on building a gokart with one of two snowmobile engines and i can't find a clutch with big enough bore to use can any one help with where i can get one
I believe i need a 1 1/4" bore on the clutch
I Thought i might run the axel through the seconddary clutch
Old 03-03-05, 04:19 PM
what is the engine off of? that will play a key role in finding a clutch
Old 03-05-05, 01:00 AM
diagnosticmonke
Talking Call Denny
Theres This Guy In Northern Minnesota Whos Got Parts Out The Wazoo For Just About Anything> Denny 218-875-3541. No Computer Up There Man :d
Old 03-07-05, 01:11 PM
puey61's Avatar
Hey punk, one thing to bear in mind. I've yet to see a sled engine that is not a tapered shaft crank. You likely will not find a centrifugal clutch with a tapered bore except those on a sled.
Old 03-07-05, 05:21 PM
Welder
clutch
Hey Skater
You may have to rig up a jack shaft to get it to work...
Welder
Old 03-09-05, 10:05 AM
skater_punk8
I thank every one for there im put does any one know if i can put an axel through a scondary clutch
Old 03-21-05, 09:18 PM
lazzer408
No you will need a reduction of 5:1 to 7:1 depending on tire size.
