Mini motorcycle problems help!! (2 cycle motor)
So this is the problem.
To begin with. It has an auto start alarm on it for one. When I
connect the battery to the moto it automatically turns on. It won't
turn off until the battery is disconnected. When I try to accelerate
(turn the gas make it move). It goes no where. I have the oil and
fuel ratio match correct. The fuse is also good. What else could it be!!
Its just weird because
when I connect the battery it turns on. Then when I turn the key it makes
a different higher pitch noise. ??
here is a pic of the bike
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Received 2 Upvotes
I'm not at all familiar with these scooters but based on my knowledge of similar equipment, here are some things that come to mind to check out (and if so equipped within the electrical system): Key switch faulty; Solenoid faulty or; Faulty relay switch. All of which you would need some knowledge in electrical diagnosing and a test light as well as a multi-meter.
