Rod cap hitting cam shaft
Old 04-01-05, 06:58 PM
welderguy
I have a 5hp Briggs gokart engine. I just go new rings and stuff for it. But today i was putting it all back together and the rod cap is hitting the cam shaft and i dont know why it is doing this. Please help me.
Old 04-03-05, 06:38 PM
I'm not sure how you've got the rod cap hitting the camshaft. Tell us more. What kind of engine is it? You said it was a Briggs. Is it an overhead or side valve? You mentioned new rings and stuff. What is "stuff" did you get a new; connecting rod, cam shaft, crank...?
Old 04-06-05, 04:15 AM
puey61's Avatar
Do you have the rod/piston assembly installed 180 degrees off? If you removed the rod from the piston, did you reinstall it in the correct position to the piston?
Old 04-08-05, 04:04 PM
puey61's Avatar
How'd you make out welderguy?
