timing on 5 hp briggs
Old 04-10-05, 05:42 PM
welderguy
how do set the timeing on a 5.5 hp briggs go kart engine. On the Cam there is a dot but there is nothing on the crankshaft gear. So im not sure on how to set it correctly. Pleas help
Old 04-13-05, 03:04 PM
puey61's Avatar
If, on the crank gear, you don't see a dot, you may have it installed backwards and can't see the dot OR this gear may have one of the teeth camferred. This would be the timing mark in this case.
Old 04-14-05, 04:17 PM
welderguy
it has the dot on the cam but on the crank shaft gear. And i have looked on both sides
