gocart problem
Old 04-12-05, 09:21 AM
jonnyd
gocart problem Help!!!!!
Hi I an 14 and I have an old gocart.I am haveing a problem with the engine, and old briggs and stratton 5 hp. When I start it it goes as fast as it can and wont stop! help
Old 04-12-05, 05:17 PM
your throttle linkage is messed up, i had the same problem with mine when i had it.
Old 04-13-05, 02:58 PM
puey61's Avatar
Or...the carburetor is varnished up and won't allow for free movement of the throttle shaft. Or...if speeddriven is right, you'd better get a Briggs manual to refer to as governor/throttle linkage/spring arrangements are confusing. The book will help you through it.
Old 04-14-05, 11:33 AM
jonnyd
yeah I might have messed something up when i took it all apart and cleaned it.
Old 04-14-05, 11:56 AM
jonnyd
I looked at the manual and it did not explain how to do it. Oh and right now i do not have a spring on the governer. If i have it on it goes as fast as it can.
Old 04-15-05, 05:15 AM
puey61's Avatar
jonnyd, take a look at the thread entitled "Go-Cart Briggs 5hp throttle problem" in this forum. That guy has the same problem, I believe, that you have. That thread should help you out.
Old 04-17-05, 06:42 PM
jonnyd
no this is not the same problem that i have. and so no it does not help. sorry
