6.0 techumpsh
6.0 techumpsh
ivem got a gocart with a 6.0 techumpsh(sp) engine runs great but willnot idle ive cleaned the carb 4 times same result could it be the valve adjustments
tecumseh power sport 6.0
We recently purchased a used Go-Cart for our son. Due to the gas pouring out the throat of the carburetor. We went on a search for information.
We found tecumseh web site & under customer Service we found Owners manual & troubleshooting/service manual.
Hope this is helpful
http://www.tecumsehpower.com/CustomerService/BSI.pdf
Received 2 Upvotes
You said you've "cleaned" the carburetor 4 times but not by what means. A bath-type cleaner is by far best. I use Napa #6401 cleaner and have excellent results every time (unless you have rust issues with the carb). I've yet to see a spray cleaner do a good job on those carbs with heavy varnish build-up.
