painting/ need to get off brake line.
Old 07-12-05, 12:50 PM
mancoowner's Avatar
ok, as you know i am in the process of some painting on my 4-wheeler. i'm working on the front left side currently. i have the tire off (painted rims yesterday) and i have removed the left steering connecting rod, 'pitman' arm that connects the steering rod to the 'knuckle' and the top and bottom A-arms. i have sanded and painted all of the mentioned parts. now i want to paint that knuckle but to get it off i would have to remove the brake line connected to it. the manual says i have to bleed the whole system to take it off. when i just loosen the nut it starts to bleed and i cant get a ratchet on it to get it off quick enough and hold it above reservior level. is there anyway i can get it off with very minimal bleeding then plug it so i dont have to drain the whole system for just the one side?
Old 07-13-05, 07:18 AM
You could just have a clean container underneath it so that you dont have to replace the fluid and then just put it back in the reservoir.
Old 07-13-05, 05:57 PM
pangborn83
remove the caliper instead of takeing the line off at the caliper maybe?
Old 07-15-05, 09:36 PM
Tie the brake handle back so brakes are slightly applied. This will prevent master cyl. draining completely. After you reattach brake line you'll have to bleed the brakes.
Mike
