Yamaha radiator fan
Yamaha radiator fan
I have a Yamaha Kodiak 450 2007, My hot engine light keeps going on. I think its the fan because i then noticed it didnt click on. I was going to run a wire from the battery to the fan to see if it would start. Someone else said i can unplug the fan and connect them to test it to see if its that. Any recomendations?
First check the fuse.
The fan probably has a hot lead and a ground lead. First check the ground lead. Make sure it's clean and shiny and firmly connects to a shiny spot on the frame. That may solve it. If not, then run a test wire from the plus battery terminal to the hot lead of the fan. Fan runs, may be temp sensor. Fan doesn't run, check fan.
