idle on skandic
Old 12-22-05, 12:38 PM
idle on skandic
How do u adjust idle on dual carbs?
Old 12-28-05, 03:44 PM
CRBENDER
Dual carb adjust
What year are you talking about? I believe you are talking about the round slide Mikuni's, and if so, most of them were set so you could put an 1/8" round rod such as a welding rod or 1/8" drill bit down the throat and adjust your idle stop screw so you just had a little tension on each slide, then you started the sled and if the idle speed wasn't to spec, you adjusted both slide stops equal turns, in (clockwise) to increase idle speed and out (counter-clockwise) to lower idle speed.
Old 12-29-05, 08:29 PM
1993 is year and i have a pic of carburator it has 2 screws on it one is called idle adjusting screw which i'm thinking controlls mixture,the other is a thottle stop screw and has something to do with the thottle valve,or either of those what u are talkin about?
Old 12-31-05, 08:29 AM
CRBENDER
idle
Yes, the throttle stop screws are what you are looking for, the idle adjust screws are for the mixture at idle to about 1/8 throttle.
