1991 340cc Indy Lite Exhaust Modifications... HELP!
Old 02-01-06, 05:38 PM
I have a 1991 340 Indy Lite that i want to get more acceleration and/or speed out of it without spending much money. Does anyone have any tips on modifying the exhaust?
Old 02-13-06, 07:57 AM
diagnosticmonke
The answer lies in the clutching
The best place to start is from the bottom up. Studding the track will certainly help you connect. Next read up on your clutching. Polaris makes some of the best clutches to modify as far as being easily tuned. After you understand the way they work , youll find adjustments easy. Then you will notice the improvements your looking for. Unless you have access to a dyno, exhaust flow and carburetor re-jetting is all guess work, which in most cases only robs performance. Happy trails
