HELP!!!! PROBLEM with a Schwinn electric scooter
Old 06-21-06, 08:55 AM
It runs very slowly...I took it apart and it has 2 little 12 volt batteries under the footboard....when I tested it, I got 13.19 volt for each battery and 26 volts DC total on both of them and I also tested the little fuse in there and it is not broken it still looks good and has continuity When I put everything back together and turned on the handle the Schwinn S350 electric scooter barely even turns when I have the back tire off the ground. Could the brushes in the little metal box next to the batteries be bad?? If you reply...please walk me thru it...I'm not the best with a volt meter....and you'll need to tell me which wire to test and what # I'm looking for.
Thanks Kyle
Old 06-21-06, 11:43 AM
Hi, We are not ignoring your post. I don't know anything about them. I sure someone who knows about them will reply soon.
Best regards, Jeff Z.
