HELP!!! with a 6hp engine.PLZ HELP!!
Old 07-17-06, 08:54 PM
ok i bought a tecumseh 6hp 4rm a guy. can anyone tell me if thats a good brand?? my problem is when i turn the choke off my engine just turns off or like chokes out. at times it does run with it off and goess reallly fassst.its also missing the air filter. Wat can i do?? thanks
Old 07-18-06, 03:55 PM
I would start with the carb. Give it a thorough cleaning (remove it, disassemble, soak and reassemble it properly and adjust).
Old 07-18-06, 05:19 PM
I kind of have a problem like that, except Mine won't start unless I'm going 5 mph. do you think I should do te same thing?
Old 07-18-06, 07:47 PM
I jus bought sum carb cleaner do u think dat would work ? do u think i should get a air filter? thanks
Old 07-18-06, 07:48 PM
Replace the springs on the carb is this vane idle controlled
Old 07-18-06, 09:25 PM
i have no idea wat dat is. where kan i get it? is there n e way u kan send me a pic of it ?
