no spark/ starting issue
Old 10-23-06, 07:23 AM
Exclamation no spark/ starting issue
I have an 85 honda 4wheeler and I have replaced the cid and the stater, in the pull cord compartment. Still have no spark what else could it be? Any help would be appreciative.
Thank You
Old 10-28-06, 12:13 PM
no spark
Thank You
did you test the stator for readings?
is the cdi you put on know good.
check you on off switch also they sometimes go bad
Old 11-21-06, 05:14 AM
i know this sounds like a simple question and answer but did you check your plugs?
they do fail as well
Old 12-15-06, 09:08 PM
One of the major problems with electrics is they require a good ground. Many have pulled out their hair replacing parts only to discover the problem is ground.
Make sure all devices are grounded. This is more of a problem with left out in the rain or in very humid climates. Also check the kill switch, it could be faulty, like grounding out, disabling a flow of electricity to the components to the plug.
Also check the coil. I could go on but the best is to start at the plug and work backwards, proving to yourself each item is solid and flows electricity.
Best of luck.
