Kawasaki Mule overheats easily
After running my Kawasaki Mule utility vehicle around for a short while, it will overheat and it won't restart until the next day. Another problem is when I initially start it up with the choke out, the engine revs really high and then goes down, revs high and then down again. When I push down on the choke to ease the reving, it stalls. Any suggestions.
Thanks for your help.
Overheating: Check the cooling air intake area to make sure it is clear. I've had a bird build a nest while it was parked outside for 6 hours, and I've clogged the cooling intake on my golf cart by driving through a field of tall, dry grass.
