Golf Cart Runs Poorly
I don't know what the manufacturer is but, I think its an EZGO. I checked compression and its 130, it has a new spark plug, but it has a weak spark at the plug. The coil primary tests at 4 ohms and secondary ay 12K ohms. I have removed the carb and disassembled and cleaned. The coil primary wires come from a box which also contains wires going to engine. Can this box cause a weak spark. It also backfires when you relase the gas pedal. Dealer told me that the govenor and the accelerator pedal aren't syncronized.
Where can I find wiring diaghram and troubleshooting for this. Thanks
