Mag Gap On Tecumseh
Old 07-05-07, 06:30 PM
R
Question Mag Gap On Tecumseh
i need to know what the gap is supposted to be for the magneto on a 6.5 horse power sport tecumseh go kart engine?
Old 07-05-07, 08:57 PM
Received 30 Upvotes on 29 Posts
Air gap on coil to flywheel - .010.
Align magnet with coil pickups, insert matchbook cover in the gap, loosen the coil let the magnet pull it down tight, tighten the retaining screws, rotate the flywheel a little and remove the matchbook cover. You are ready to go.
Hope this helps,
Bob
Old 07-06-07, 06:46 PM
R
k, thanks, got the gap set. Now it will run on half choke, but as soon as you flip the choke off it idles very high for maybe 1 or 2 sec and then it just dies like its running out of gas so we pulled the carb off and were gonna soak it and clean all the jets and see if we can get it to run right. we think we might have run a tank of bad gas through it. Thats when this all started.
Old 07-07-07, 06:20 PM
I think you're on the right track. It sounds like a dirty carb issue. After soaking it blow it out with compressed air if you have it handy.
Good luck,
Bob
