1983 honda atv 3-wheeler carb.adjustments
Old 01-02-08, 10:43 PM
Angry 1983 honda atv 3-wheeler carb.adjustments
Runs great,won't idle perfect. Need to know the settings for the carb adjustments...Please help!!
Old 01-03-08, 04:26 AM
I
I had a 185 honda ATC. I had similar problems with it not idling. Its been a long time since I had that old machine, but what cured my problem was a carb rebuild kit.
Old 01-09-08, 08:55 PM
G
Run some Sea Foam or fuel stabil thru it if that does not fix it then close your low speed jet all the way the open about 1 1/4 turns , you'll have to play with it you may have to pull your carb and clean your low speed jet , it ma be plugged
I have a 1984 Big Red and a 1984 Four tRac both original both have lost the low speed gear but still do good on high!!
