1983 honda atv 3-wheeler carb.adjustments
Runs great,won't idle perfect. Need to know the settings for the carb adjustments...Please help!!
Run some Sea Foam or fuel stabil thru it if that does not fix it then close your low speed jet all the way the open about 1 1/4 turns , you'll have to play with it you may have to pull your carb and clean your low speed jet , it ma be plugged
I have a 1984 Big Red and a 1984 Four tRac both original both have lost the low speed gear but still do good on high!!
