kawasaki fd 620 engine timing
Old 01-17-08, 10:51 AM
i am having trouble getting my engine timed on my mule. ive done everything by the manual but still no go. backfiring through the intake gas in the oil. i know they changed from a plastic cam gear to a steel gear are thr timing marks supposed to be lined up different now?????????????? HELP!!!!!!!!!!!!!!
Old 01-17-08, 04:15 PM
Received 3 Votes on 3 Posts
The timing marks should line up the same. What all have you done to it. Were you replacing the cam and it started backfiring or did this just start while running it?
Old 01-17-08, 04:27 PM
i rebuilt the entire engine but the cam and the heads came out of another 620. i was told this wouldn't matter. i've got gasoline in the oil, when i try to start it it "hangs" with the choke on, crank its but off with the choke off, good coils, good spark, i had this problem with the last one i rebuilt, thought it was put together wrong or something. i have rebuilt probably 6 of these no problem but the last 2 are killing me
Old 01-17-08, 05:00 PM
Sounds like ignition timing/carburetion. More on the timing. Cam timing shouldn't put gas in the oil.
