ski-doo mxz 583
Old 02-04-08, 02:24 AM
ski-doo mxz 583
I can start the sled when it is cold but when it warms up it shuts down and wont start again until it cool off,and the only way it will stay idling i have to play with the throttle can anybody help me............
Old 02-04-08, 01:50 PM
G
Will it run with the choke on?
Old 02-04-08, 03:23 PM
mxz583
their is no choke their is a primer button......
Old 02-04-08, 08:33 PM
K there is a linkidge on the carb or a screw adjust the link till it idels at a smoth but (NOT TO HIGH)we dont want it to take of on u with out u on it and if it has a set screw thin turn it right till it eather stalls or stays running and if it stalls thin turn left and for the other prob check the oil change it maybe that will help and u are not letting it sit there to get hot are u thows machines are air cooled hope this helps let me know Joe
Old 02-05-08, 03:38 AM
I will try that today and let you know..........
Old 02-05-08, 08:42 AM
G
will it continue to run when you push the primer lightly
Old 02-05-08, 05:31 PM
k well hope it help let me
Old 02-08-08, 03:13 AM
583 mxz ski-doo
I fixed it.... did compression test 1cylinder had 30 psi and the other had 125 psi had to put new piston and rings in now it works like it was new again thanks for your help ....... joe
Old 02-09-08, 09:02 PM
no prob any time
