problem with my club car
Old 02-08-08, 07:14 PM
i have a club car that is pretty old and it doesnt go. i hit the pedal and i can hear the solenoids click in but the motor doesnt turn.
Old 02-11-08, 02:53 AM
You will need to go over your electrical closely. If the machine was working fine and then just started acting up I would check and clean battery terminals,wiring connections and switches. The battery water and condition also. Having battery acids close to small wiring can case many problems. Check the solenoid relay to see if it is passing current to the motor. Check the reverse/forward switch wiring.
I have a older EZ go and it has stopped on me several times and most often or not it is just a cable or wire connector.
