polaris 400 xplorer 4x4
Old 03-25-08, 09:06 PM
I bought this four wheeler today for two hundred. Its in good shape but I have just on problem. For some reason the spark plug will only fire once when hitting the start button. Does anyone know why it might do this? Turns over good and getts fuel but not enough spark. I just wanted to say thanks in advance.
Old 03-27-08, 08:20 AM
It would likely be the magneto/coil. I would check all the wire connections first, including the ignition switch to make sure it isn't grounding the system out. What year is it?
Bob
Old 03-30-08, 04:58 PM
once fire
yeah, check connections first, make sure grounded. probably going to be stator.
Old 04-04-08, 03:16 PM
hopkinsr2's Avatar
These Polaris 4 wheelers have a safety switch in the throttle. Make sure the throttle cable isn't sticking. If it's Ok, check the switch. Good luck, roger
Old 04-28-08, 12:38 AM
Unhappy Xplorer
I HAD THIS HAPPEN TO ME AND IT WAS THE MAGNETO NOT CHEAP
