2000 Honda Recon 250 ATV
Exactly what the title says. Runs great. Recently it started moving forward when clicked into gear. its semi auto so no clutch. its not idleing high, its just like it was before, but now when put into gear it starting moving forward. same with reverse. not sure why all of a usdden this would happen. any ideas?
thanks
Jack
thanks
Jack
Did that to me on the first Quad I ever bought right after I changed the oil.
Guy I bought it from used regular oil.
I put in the CORRECT motorcycle oil and had to readjust the clutch - it suddenly started grabbing with every shift.
Easy enough - check your owners manual for clutch adjust. Take it to a dealer if you're not fuzzy about approaching your machine with a screwdriver.
