How fast does a average atv?
Old 05-30-08, 12:32 PM
Go in first gear? I need to know because I need to gear an invention of mine so it will have good low end power. Just a pretty good estimate is what I need, nothing exact.
Thanks
Tornerito
Old 05-30-08, 12:42 PM
What are you asking? How to gear an ATV down for low end torque? You aren't providing much information here.
What kind of ATV is it?
Old 05-30-08, 06:06 PM
sorry...
Ok lets make it a bit clearer. I built myself a small fourwheeler.
And I am in the process of putting a different motor in it.
It had a 5Hp now I'm going 6hp and a better engine. But I have an engine and a separate 5 speed transmission, so I can play with engine to transmission ratio. What I want to know is, what should my speed in mph be in first gear? I to gear it so it has good performance in first gear (Mud, steep terrain) Top(5th gear) speed is not really an issue. So I need to Know what for example is the "normal" (I know it varies with make, model, 2/4cycle .etc) at which a gear change (1st-2nd) is usually necessary.
Now maybe that made it even more difficult to understand
Old 05-30-08, 06:20 PM
Take your engine rpm and do the math according to the gear ratios and tire diameters you have. That's the math taught in junior high school.
Example:
engine rpm=3000
gear ratio=10 to 1
output rpm=300
Then you have output rpm and axle ratio, then tire diameter.
Figure out how many inches around the tires are, how many tire revolutions it takes to go 1 mile, and the rpms of the tires.
MPH is your answer.
Old 05-30-08, 06:27 PM
Example:
engine rpm=3000
gear ratio=10 to 1
output rpm=300
MPH is your answer.
Ok I don't need to know how fast it will go. I already have all that ratio deal done. What i need to know is what i an ideal 1st gear speed so I can gear accordingly.
Old 05-31-08, 06:33 AM
the_tow_guy's Avatar
Some help maybe:
http://www.atvriders.net/atvtopspeeds.htm
I'm thinking if you top out at 15 mph or so in 1st, you'll have a fair amount of pulling power.
Old 05-31-08, 06:40 AM
Hey!
Perfect, perfect,
Thanks a million
Tornerito
Old 05-31-08, 06:47 AM
That's why they pay me the BIG bucks.
Be sure to post back how it turns out, etc.
