96 ez-go
Old 06-21-08, 09:03 PM
Smile 96 ez-go
i have a 96 ez-go that sat idle for about 6 months when i started to use it i drained all fuel and replaced the battery. the engine started and ran for about 15 seconds and has not started since it seems to fire 1 time very weak when you try to start it. any suggestions appreciated
Old 06-22-08, 05:43 AM
When in doubt I always start with fuel.
Puting in new fuel does not hurt but it does nothing about the old fuel & dirt in the carb. and fuel lines. That initial 15 second run could have been just long enough to suck a piece of dirt or varnish into a tiny passage or jet inside the carb.
You can remove the air filter and put a teaspoon of gas down the throat of the carb (or give it ONE small shot of ether) and see if it fires or runs for a few seconds. If so, you probably have a clogged carb.
If you are a thorough type person:
remove and disassemble the carb. and soak overnight in carb cleaner
give the carb a good clening making sure the jets and all passages are clear
replace fuel filter and fuel lines
Old 06-22-08, 07:39 AM
Cool 96 ez-go
did it all still no spark except for the very first time that you push the accelerator down. maybe the coil!!!
Old 06-22-08, 12:47 PM
Angry 96 ez-go
took the coil off and swapped out this is not the problem.maybe the ignitor or flywheel. what about the switch?
Old 06-23-08, 01:21 PM
96 ezgo
sound like the ignitor, make sure you have a good connection with the 2 wires that go to the coil, i have had them just quit in the middle of doing morning chores. (mowing greens)
also give the 2 coil wires a clockwise twist to insure a good connection, hope this helps, chris
