Kawasaki bayou 220 clutch/trans help?
Old 09-27-08, 08:30 AM
I recently inherited a 1999 kawasaki bayou 220 for my 12 year old daughter from a well meaning co-worker. It was parked last year with clutch troubles. He tore the clutch side engine case off, as well as the primary clutch and secondary clutch and shifting mechanism. It turns out the secondary clutch disks are bad. My question is, how can i be sure the transmission in in neutral when re-assembling the motor? The clymer manual just says make sure transmission is in neutral. How do you check? Thanks!
Old 09-28-08, 10:24 AM
If it is in neutral you will be able to spin the input shaft to the transmission by hand.
good luck with the project
