Surging on Murray go kart with Tecumseh OHH60
Old 09-29-08, 05:01 AM
I am working on a 5 year old Murray with a OHH60 engine.
It would not start, but after cleaning the carb almost all appears fine and it seems to run well under power.
However, the governor seems to be commanding a continuing engine surge, about one vrooom per second at what is supposed to be idle. I can hold my finger on the butterfly and it will seem to idle without dying, but as soon I let it loose the surging starts.
All the springs seem to be right. What is the next step in resolving this? Is the governor stuck or something?
Old 09-29-08, 05:22 AM
It sounds like the carb. seeds a little adjusing. I'm not familiar with that engine. Can you adjust the high and low speed jets?
Old 09-29-08, 10:31 PM
Old 10-01-08, 09:07 PM
There appears to me to be no adjustment to the jets - the carb is rather clean.
I also had the book below but it does not seem to address this issue.
Old 10-02-08, 04:23 AM
Here's a link to a service manual on Tecumseh engines. It downloads in PDF format - pretty comprehensive. It may have about the same information as the posting by "imliljim".
http://www.cpdonline.com/692509.pdf
Most surging (or hunting), assuming linkages to the governor/carb are tight, comes from a lean mixture. That could be an adjustment, as Pilot points out, or a jet that has a partial blockage. If you can even out the surging with a partial choking of the engine = lean mixture causing the problem.
Check the bottom of the float bowl for a needle adjustment. That would be for the main jet. If adjustments don't work for you, I would think about taking the carb apart and cleaning it.
