Electric 05 ezgo problems
Old 12-10-08, 12:33 PM
Has been set up for hunting. Problem i'm having is that while im traveling if i stop it doesn't want to start again. Do i need to upgrade the motor or the controller? Also it has good speed but not alot of torque. How can i improve the torque but not change the speed? THANKS
Old 12-15-08, 05:48 AM
When you say set up for hunting. Do you mean larger diameter tires or just high clearance? If you increase the diameter of the tires and the loads with hunting gear you may lose some torque and power coming from motor.
I think it all depends on a couple of things. If it worked ok after you set it up for hunting and it just started acting up
it could be brushes,battery age and connections and wires. However if you have changed the tire size and load on the cart you may just be overloading the motor and drive system.
I think they make heavy duty motors and controllers for such projects but you better have a big checkbook.
