Honda Fourtrax 300 No spark
Old 01-16-09, 06:13 AM
T
Question Honda Fourtrax 300 No spark
Okay, so here's the story. A neighbor here at work bought a Honda Fourtrax 300, a 2000 model.
The thing has been very misstreated and has been sitting around a while I guess.
When they try to start it they don't get spark. They say they have juice up to the CDI,
But no juice gets to the ignition coil. They changed the CDI (they used one from a Honda NXR 125 bike)
and still the same problem.
The question is this, is this deffinitely a CDI issue or could there be other factors involved?
The fact that they used a CDI for a much smaller engine could mean that it would give the same problem,
couldn't it?
If anyone has any help for us I'd appreciate it
Thanks
Tornerito
Welcome To MudOilnGears Online ?(MudOilnGears Online?)
Old 01-16-09, 06:25 AM
Received 28 Votes on 27 Posts
A CDI is application specific. You would have to be using one made for that engine. The circuit for the spark is battery/switch/CDI/coil/spark plug. If you have current to the box and not through it, I would say the box is the problem.
I would check all connections for continuity and grounding, but it sounds like the problem is in the CDI box.
Old 01-16-09, 11:10 AM
T
In other words, If you think it's the CDI and put in one that isn't made for that engine you aren't getting anywhere. Is that right?
Next, if all cicuits are properly grounded, and there is continuity let's say from switch-CDI, and from CDI-coil.And you have current up to the CDI, then it has to be the CDI. Am I still on th right track?
The deal is the CDI costs around $200 and it wouldn't be nice to spend that, and then find out it's something else
Is there any way to test a CDI with a tester or something?
Thanks again
Tornerito
Old 01-16-09, 03:07 PM
Pretty much as far as what is wrong with it. If you had a CDI box from two different applications, but the box carried the same part number or specs, you could possibly get away with a cross application. Keep in mind without testing something to determine it's faulty, there is a greater risk of replacing the wrong part. The process of elimination only goes so far in it's accuracy.
A dealer should have the equipment/know-how to test a CDI box. Replacing a part that expensive on a guess (however educated) is not a good idea. When the electronic gizmos came out, they came with the "able to test side" as well.
Old 01-16-09, 07:20 PM
T
no spark
check all connections, grounds, etc. if you have a manual you can check many swtiches (not cdi).
make sure there is a battery and charged. there is still a good chance you still need a cdi. but I would check many other items first. you can get cdi for this quad off ebay for about $75 aftermarket
Old 01-30-09, 12:36 PM
W
grounds
Agree with the check and re check and re check all the grounds. that sounds like the main problem.....
Old 01-30-09, 12:39 PM
T
Thanks to all,
In the end they tried the original CDI on another same quad and it fired right up, so my question is answered
Thanks again
Hector
