ski-doo
Old 01-25-09, 07:19 AM
ski-doo
i have a 2001 ski-doo mxz380 fan that runs fine but has no lights at all i have put in a new volt reg. did not help for some reason the tach does not work i dont think the tech is wired in with the lights i have ckeck all plugs all seem to be in good shape does anyone have a idea on what to check next
thanks
Old 01-25-09, 08:15 AM
Received 28 Votes on 27 Posts
Is that the model with the electric start and or do you just have the pull rope?
Old 01-25-09, 09:49 AM
marbobj
it has a pull rope
thanks
Old 01-25-09, 03:23 PM
Just working off a parts schematic - I would first check at the light for current off the wire plug. You could have a bad bulb. If you don't have current there, check back through the circuit for an in line fuse. When you find that test there for current and make sure the fuse is good.
The ignition switch for that is just a two terminal switch, so if the sled runs, the ignition switch wouldn't be the problem.
Another place to check for continuity is the lead coming off the magneto going to the frame harness. The latter would be the circuit to the lights and other accessories. There is a pretty good chance the tach and speedometer run off the same circuit as your lights. I have a feeling when you get the lights going you'll have everything.
Old 01-25-09, 07:38 PM
i will check the lead from the mag to the frame. it just seems odd everything was working till we hit a rock on the trail it did take a good hit it bent the trailing arm the seld has rev. and the alarm still works
thanks for your help
Old 01-27-09, 07:02 PM
If it took a hit, it's probably a connector or a ground. Something that hard could have moved a number of things.
