briggs intek throttle connection ????
Old 05-14-09, 06:28 AM
hello and thanks for your time. i have a 6 hp briggs intek that came off a pressure washer. on the side it has a choke lever and a throttle lever. i would like to put this engine on a go kart and would need to know how to install a throttle cable. the only thing connected now is the govener arm with a rod to the carb. the throttle lever already had its connection removed. any help will be greatly appreciated. thanks
Old 05-14-09, 09:23 AM
tried the same with my grandsons go-kart, could never get it to run correctly, found out that the engine had to be specifically manufactured for a go-kart. had something to do with the way they bounce while in motion and the govenor set up.
good luck and have a great day
