briggs go cart,problem
Old 05-17-09, 03:37 AM
my kids have a go cart with a briggs fun power 5 hp motor, it seems to run fine when it is sitting still or on a smooth surface, but dies when going over bumps, any ideas what might cause this. i have adjusted the carb over and over, doesnt seem to help. thanks
Old 05-17-09, 03:27 PM
post the engine model, type and code so we can get a better idea of the fuel supply system. Have a good one. Geo
Old 05-18-09, 03:33 AM
go cart problems
the engine #s are model 136212, type 001601,
code 960314ya thanks mike
Old 05-18-09, 04:34 AM
puey61's Avatar
Try a new diaphragm, Briggs part number 272538S. It's easy to do and should be the problem. If that does not take care of the problem then post back.
Old 05-19-09, 04:00 AM
go cart problems
this might seem strange,but i noticed that it runs fine when the gas tank is clear full. after the fuel level drops a 1/2" or so it acts up again. maybe a hole in the fuel tube? thanks mike
Old 05-28-09, 10:03 AM
nearly the same engine
I have nearly the same engine and exactly the same problem. the engine model is 136212; type:002601; code:961128Y. Is the part number that you suggested the same for this engine? If not, what is it? thanks.
Old 07-07-09, 08:16 PM
dingo go kart
i went to start my go kart dingo 5 hp the other day and when i did it try to go as fast as it can by its self i messed with the thottle and clutch and nothing seems to happen i dont want to get it fixed again what should i do. 135212 is the model number
Old 07-09-09, 12:28 AM
cheese's Avatar
Can you slow it down by manually holding back the throttle on the carb?
