77 Harley Golf Cart
Old 05-17-09, 03:43 PM
77 Harley Golf Cart
At times it starts but most of the time all I get is a clicking at solenoid,Have bench tested starter and seems to be good,I switched solenoids with same results switched back same ,I'm guessing its working because it clicks when I hit foot feed If I leave it for a while sometimes it turns over but most of the time just the clicking,I also cleaned for/rev switch thinking a bad connection but didn't help Any ideas??
Old 05-17-09, 06:40 PM
hopkinsr2's Avatar
Have you had the battery "Load Tested"?? Lots of times the battery can be bad & show 12 volts on a voltmeter' but under operating load, they loose power... Make sure the connections are clean & tight @ the battery & solonoid & starter & all the grounds...For some reason, these carts like clean connections.... Good luck,,, Roger
Old 05-18-09, 09:54 AM
every connection clean and tight,Battery checked out good when load tested,still same problem,have tried jumping starter by bypassing solenoid same thing sometimes it starts some times but most time it doesn't,Could problem be bad starter ? It bench tested good ,maybe dead spot in it???
