need info Noma spirit 523 snowblower
Old 02-18-10, 11:43 AM
Thumbs up need info Noma spirit 523 snowblower
I was recently given a Noma Spirit 523 dual stage snowblower.the machine has not been run for 4 or five years. the engine is a 5HP TECUMSH MODEL #C2350030 ALSO THERE IS A CODE #2324 the current spark plug in the machine is a champion J19LM..The snowblower seems to be in great condition I would like to get it running. Any info /tips would be greatly appreciated.
Old 02-18-10, 05:40 PM
I would start by changing the gas/oil/spark plug in it and see if it will start. If it does, get some Sea Foam from an auto parts store and put in the gas and see how it does.
Old 02-18-10, 06:43 PM
If it does not start or if it does not run well (surging, needs choke to run...) then I would disassemble the carb and give it a good soak and cleaning.
Was there gas in the tank? If so you may have to drain the tank and possibly replace the fuel line. Varnish may have been deposited which loves to flake off and clog a jet or passage in the carb.
