EZ-GO Golf cart backfire problem
Old 03-20-10, 08:05 AM
K
I have a 1985 EZ-GO 2-cycle gas cart. After warming up, the engine will backfire when you step on the accelerator pedal. It will backfire from exhaust. Any ideas?
Old 03-20-10, 08:39 PM
hopkinsr2's Avatar
The first thing in my mind is the rev limiter,, but on a 25 yr old cart, you'll have to dig first... What is the spark plug like?? how old?? What is the condition of the carb &/or the fuel pump?? Old EZ-go's around here had a problem with crank seals leaking air & causing similar problems..as well as crank bearings going bad.. Make sure you have a clean carb,, new plug,, & good fuel to the carb & we''l take it from there... ..Roger
