anyone can help please?
Old 06-03-10, 09:47 AM
Need diagnosis... 2007 yzf 600r doesn't have 'lose the power It should right from the start. Then by mid third gear n up, it boggs down worse n worse.4th gear almost no power, 5th gear, won't go above 2500 rpms. No power. Suggestions? Need help bad!
Old 06-03-10, 11:30 AM
Each of your three posts in the past week have been about a different bike with a different problem??? You will have to provide more information if you want help diagnosing problems over the web. No power doesn't say much.
For your most recent bike problem:
What do the spark plugs look like?
Is it making any smoke?
Is it running smooth or rough?
Have you run a compression test?
Is it loosing coolant?
Did the problem start suddenly or has it gradually lost power over time?
Old 06-04-10, 09:23 PM
hopkinsr2's Avatar
I'v also found you post with no reply... Do you fix them,, or just move on to another??? It's kinda nice to see if the advice given helps to fix the problem,,, Roger
