Front brake not working on Harley
I have a 1995 Harley FLHTC and the front brake handle will eventually go all the way to the handle grip if I keep pressure on it. This has been coming on slowly and has got to the point if I'm on a slight hill it won't hold me from rolling back.
Would this simply be a case of bleeding the brakes? The fluid level is good and there are no leaks. Could it be the master cylinder has a bad seal and air is getting in the top?
Thanks for your help.
