97 EZGO Gas will not move
Old 09-15-10, 07:08 PM
Angry 97 EZGO Gas will not move
Today my EZGO would not move . The motor runs, both clutches are moving as they appear they should but nothing happens. F&R seem to be engaging, if I give it a little gas and shift from F to R I get a little grinding noise. Lift the wheels off the ground and they turn when you gas it though not fast and I can stop them with my hand. This is my first cart so I have no idea what the problem can be so any suggestions will be greatly appreciated.
Old 09-16-10, 03:59 AM
First I would check the cable that connects the shift lever to the transmission. Hopefully it has just come loose or is out of adjustment. You can also try putting it in gear by moving the lever on the transmission.
