tecumseh 4 hp no spark
hey guys new to site. have a old minibike with 4 hp tecumseh-- model hs40-55394c . no spark, what to check first ?
thanks, david
thanks, david
Check
If there is no spark you have a problem with your electronic ignition. Check the gap between the flywhell and the electronic ignition. Should be around .012 or a business card width.
You may also have a ground somewhere. Take the wire off the bottom if the electornic ignition. Then see if you have a spark. If you do, you are grounded and have no spark at the plug.
Might want to check you have a good plug too.
Good luck!
Good luck!
I agree with the " points and condenser" I bet a quick swipe with a narrow folded strip of sand paper and you'll be all over that back yard like a hobo on a ham sandwich! Ride safe!
In my experiences its usually the condensor that dies. Pretty cheap to replace. Make sure the points are clean & gapped correctly. If its the coil I believe there is a way to test continuity to find out if its open or shorted.
Good luck & let us know if you get'er goin'!!!
TexasFire
TexasFire
