lawn tractor
Old 11-19-11, 09:47 AM
lawn tractor
I haven't used it in about a month just went out to cut grass n tractor wont start just put new battery n starter about 4months ago. I turn key n it will turn over real slow even with jumper cables hooked up, like starter is bad, if i pull plugs out it spins fast
Old 11-19-11, 12:36 PM
I would pull the battery and have it checked. I had one new battery that lasted about one month and the replacement (same brand) has gone seven years so far. I would suggest that you get an intelligent type trickle charger and hook it to the battery when you are down for more than a couple of weeks.
Old 11-22-11, 09:23 PM
pist-n-broke's Avatar
Hi,
You can maybe also check your ground cable connections at the chassis, and not knowing your model, your valves could be out of adjustment effecting the decompression feature.
Hope this helps.
