Yamaha gas Golf cart quit running :>(
Old 06-03-12, 12:10 PM
1997 Yamaha G16 Just stopped... thought it was gas but had plenty. Will not turn over when gas pedal is pressed. No clicking... nothing. I jumped the big terminals on the solinoid and the engine turns over... but will not start. Oil level is full, I pulled the spark plug... it was a little sooty but I've seen worse. I jumped the two solniod terminals with the plug connected and laying on the head, but did not see any spark.... but I'm not sure I would get one, if it will not turn over when pressing the gas pedal down HELP !!
Old 06-20-12, 05:04 PM
can check under plate on floor,theres a switch there that sends power to the solinoid,can put a voltmeter on wire at solinoid see if 12v when pedal is pushed,can check key switch also
