Honda Rancher 350 ATV won't start
Old 04-03-13, 10:56 PM
W
Question Honda Rancher 350 ATV won't start
I started up my Rancher after the winter and after about 20-30 seconds it stopped. I have been unable to start it again. It will fire briefly when I inject fuel vapor into the air cleaner. I have drained and changed the gasoline and have added a carburetor cleaner to the new gas. I have sprayed carb cleaner into the air intake. Not even a pop. No gas. What next?
Old 04-04-13, 12:49 AM
Received 584 Votes on 550 Posts
Welcome to the forums.
Can we assume that as part of the winterization process..... you turned off the gas to the engine and ran the carburetor dry ?
If you didn't.... your carb is now gummed up from last years gasoline with ethanol. It will need to taken apart and completely cleaned.
Old 04-04-13, 08:38 AM
G
Received 2 Votes on 2 Posts
I think PJ max hit it right. Corn is good on the cob but not in a gas tank. Spray cleaners do not clear the jets and passages in the carb and most additives will help if added before storage, but not after. It's tear down time.
